Home > eBay & Bargain Spots > Cheap TDV8
dhallworth
Cheap TDV8
All you need is a HUUUUGE bottle of T-Cut!!
http://auctions.motorhog.co.uk/vehicle-lis...&srch=
Post #244118 21st Feb 2014 8:04pm
RR2008HSE
Excellent deal! I'm remembering the unfortunate gentleman whose TDV8 ingested its turbo with fatal results. At £680, with a good engine, that would be quite a deal. Also, a number of interior cosmetic trim pieces are well above €680 EACH!
Post #244165 22nd Feb 2014 2:51am
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Maybe we could all chip in and have it garaged up somewhere for bits when required!
Post #244172 22nd Feb 2014 8:50am
OK here is my $40 , now can I have the engine Thumbs Up
Don't think it can stay at that price for long though . 2008 MY Supercharged
Post #244174 22nd Feb 2014 9:08am
dhallworth
It looks in nice condition everywhere else apart from that corner.
Looking at the chassis leg though it looks bent back on itself, I wouldn't be putting my family or friends in it as even after replacement you've got no guarantees it's as strong as it was. It'd probably be OK but it wouldn't be a risk I'd take Smile
It says on the window "no turnover" so you'd wonder what has broken on it, it could be electrical or it could be mechanical. If the starter has been hit by things moving could it have broken the casting that it's bolted to?
For the money it's at just now it's a no brainer but if it does start to rise sharply (my estimate is circa £15k finishing price) then it's not worth the risk. It might never drive quite right, it could scrub tyres if the suspension isn't quite right etc.
My guess is for it to have been written off there must of been £20k's worth of damage for it to be repaired as a good condition 2010 is still worth over £30k. Isn't this also the MY that they took the Brembo brakes off them?
Post #244245 22nd Feb 2014 3:54pm
It is cat d which means it should be repairable, but thats not to say its not going tk take a huge effort, at a few hundred quid its a no brainer, but it would take having it in the air to have a look to see what is bent, obvoiusly the suspension is gone, but that has probably taken the subframe with it, possibly the top mount for the strut whch seems to be too far over, if the screen needs replacing it possibly means the frame is deformed, there is a turbo behind that innner wing, the fbh in there also, that will most likely have gone too, so it all starts adding up, all to be left with a cat d repaired car at the end of the day.
Engine also seems to be sitting in slightly the wrong place! There is nothing that can't be fixed with a hammer😜😜
Post #244254 22nd Feb 2014 4:28pm
TBH i think it would have been valued at even more for the repair and i bet a new shell would have been mentioned once or twice as the easiest option...
I think its still possible it could prove a bargain but only under £9-10k as above that your aking a big big risk as it will only be worth £20-24k when done as a CAT write off.
The engine may not be turning over if the pyro charge on the battery lead has gone or one of the many other electrical gremlins showing on the dash is covering something up. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #244646 24th Feb 2014 2:12pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
More prob go to a ringer tbh _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #244792 25th Feb 2014 1:14pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
SE with no RSE??
Post #244879 25th Feb 2014 8:45pm
73vse
Facelift didn't get rse as standard ,
Post #244886 25th Feb 2014 9:00pm
