![]() | Home > Maintenance & Mods (L322) > Adaptive/Cornering Lights & DRL Wiring |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
i'd connect the drls to a drl switch which you can get of ebay for around a tenner, where to wire up to can be found if you do a forum search.. |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Not 100% sure from the search but I think I need something like this http://www.ebay.co.uk/itm/DRL-Daytime-Runn...233540bff9 wired to the battery terminals and the LEDs. Hopefully this won't result in reduced engine performance.
that ebay one is a bit different to what i have at the moment..my hybrid fogs are wired to the ignition feed so the drls come on when started but its also wired to he headlight feed so when the dipped headlights are switched on the drls go off..
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Where did you get those Stan ? Ian |
supplied by Craig [CTC] |
Roger |
DRL fitting sorted hopefully with an ebay link direct to the battery.
Mine did this when the battery was low. Check the voltage after the car has gone to sleep. Does it show the warning every start up or just the first one ? Ian |
Battery shows a good charge and no other problems. The light only comes on with the other normal warning lights to show that they are working and then they go off, as far as I know they come on and off every time the ignition goes from off to position II. There is a difference between knowing your sh!t and knowing you're sh!t
LED around the headlights wired up via a £10 switch directly to the battery. Also Main beam turned on as DRL via IID Tool. Now just need to sort the cornering lights to see if I can get them working or find out if they are. There is a difference between knowing your sh!t and knowing you're sh!t
Any ideas on how to get the cornering lights to work???? There is a difference between knowing your sh!t and knowing you're sh!t
are the new bulbs you fitted ok.. ... - .- -.
The bulbs are OK as far as I know, but the lights don't come on with the replacements I fitted or the originals that where in the units when I bought the car. The original bulbs looked ok (i.e. no broken filaments) and the new ones are LED.
ok, this is what a cornering light should look like, led is the side and the halogen is the cornering light..
