![]() | Home > Technical (L322) > Front Parking Sensors |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
I think if ones gone it renders the system useless |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Rej, this link is from LR UK forums and considers in some technical detail as to what might be wrong with the front sensors on a 2004 L322. Might start the ball rolling for you.
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
I had all the front go.
| rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496
Thanks, for the suggestions. I have tried again this morning and noticed that I only get one "beep" when turned on but all other warning bongs work OK so I guess that the module has gone kaput between the test drive and now.
Apparently this is a faulty loom which is on back order so will go back to the dealer when he gets it to sort that along with the now leaking boot, dimly lit airbag light and to replace the boot clip that they lost. They have said they will give a full valet and fill with fuel to make up for the poor service. There is a difference between knowing your sh!t and knowing you're sh!t
