Home > Maintenance & Mods (L322) > Wiper Blades
RR2008HSE
Wiper Blades
What are the sizes for the windscreen wiper blades? I tried to find them in the local auto parts store and Range a Rovers were not in their book of sizes.
Is the whole wiper replaced or just the thin rubber insert?
Much thanks!
Post #244748 25th Feb 2014 8:09am
Whole wiper,
Bosch 808 off of ebay, better than standard wiper Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #244750 25th Feb 2014 8:22am
Discotigger
+1. Thumbs Up
Bosch 808, cost less than 20quid (15 quid or less if you shop around on the fleabay).
Reminds me I need to get a new set as one wiper is smearing and have started getting the annoying thud Evil or Very Mad from the wiper blades!
Post #244753 25th Feb 2014 9:00am
Sandyt
+1 the thud has arrived Mad so new blades here too
Post #244813 25th Feb 2014 3:20pm
pld118
The thud came back intermittently on ours on the motorway a few days ago... an it only had the Bosch 808's fited a few weeks ago.
Post #244816 25th Feb 2014 3:40pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Me too. New Bosch blades in Jan. Thud, albeit not as bad as on originals, has returned. Is there a quality issue with new Bosch blades or is eBay the problem? Or is it the whole arm that is wearing? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #244818 25th Feb 2014 3:44pm
cant remember who it was but they suggested squeezing the 6 pivot joints together to get rid of any play..
Post #244822 25th Feb 2014 4:06pm
The thud also comes from the wiper blades not being in the correct plane North/South... undo the nut on the wiper arm and you will see an aluminium holder under the arm which allows the arm to tip forward and back... To stop the thud! Simples Thumbs Up
Post #244830 25th Feb 2014 4:39pm
do you mean this bit Craig..i tried this on my td6 and just couldnt get rid of the thud, probably unlucky getting the right setting..
Post #244836 25th Feb 2014 4:56pm
Which one for the rear chaps? Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #244845 25th Feb 2014 5:18pm
2 for a quid in the pound/99p shops ...18 inch ones Adam..
Post #244846 25th Feb 2014 5:19pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
are they 808s for a 2003
cheers nige
Post #244888 25th Feb 2014 9:27pm
pld118
quote RRUK - Which one for the rear?
From the ECP website, I bought and fitted this 19" rear blade Adam, for £8.52 delivered. Very good quality:
" Bosch Rear Wiper Blade Retrofit Flat Wiper Blade Single Ar19U Part No.: 485778190 List Price £11.99"
Post #244889 25th Feb 2014 9:42pm
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
I might of already mentioned this but I was surprised when I replaced my wipers with the Bosch 808 that I still had the annoying thud.
So then replaced the little clips ( from Dan ) that connect the wiper to the arm - problem solved Very Happy 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #244896 25th Feb 2014 9:52pm
i think because the wiper itself is so heavy the 'working' bits like the pivots and clips because loose and cause the thudding..
Post #244898 25th Feb 2014 9:56pm
