Home > Technical (L322) > 2007 to 2012 headlight wiring
Petr
2007 Range Rover Vogue SE TDV8 Java Black
Hi guys
I need some information on how I upgrade my wiring from my 2007 l322 to the new lights I have fitted.
I brought new black 2012 lights from land rover. Cost a lot but they look a lot better than the 2009/10 grey inserts.
There are a few wiring diagrams in forums but they all seem to be people converting 2002 cars.
From doing my research the 2006/7 headlight wiring differ.
If I just plug in this is what works
Main light
Beam
What does not work:
Led rings
Indicators
I believe there is a few pins that need to be relocated in plug but not to sure
Look forward to your reply guys
Thanks
Post #245350 27th Feb 2014 9:32pm
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Best person to speak to is Cam Tech Craig (site sponsor) as he's the man for the conversions Bow down F**K IT you only live once
Post #245355 27th Feb 2014 9:58pm
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Hi, if you use the search and put in 2010 facelift the thread by Flashman is what I used the pin locations are bang on get yourself a tester and its straight forward, hope this helps.
Post #245358 27th Feb 2014 10:20pm
