![]() | Home > Technical (L322) > Tdv8 gearbox fault |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
Cossie, did you happen to see the parts that had failed? I just wondered if you knew whether the output shaft had failed in torsion or if it was the spline that had stripped (presumably as a result of wear due to fretting corrosion/brinelling, which is what the anti-seize paste is designed to prevent)
