![]() | Home > Technical (L322) > It no start! |
Had your battery gone flat after playing with IIDtool all afternoon? It can happen. Otherwise as GFM says, possibly.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi J90, giving out 14.7v with the engine off. The reconfig via IID was with the engine on until the writing to CCF that requires the ignition in Pos1. So I think the prob is more mechanical than electronic. FF's, they are a pain in the |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
you should have the engine running if you use the iidtool more than ten minutes.. ... - .- -.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
not a chance |
Yep Stan, did all that as per the IID instructions. I don't think it is a problem related to the IID, just an unhappy coincidence. Off to the garage this morning so I'll post an update later.....Oh and I need my air suspension dryer unit replaced...happy days! SDV8 AB MY 2019
Dodgy battery terminal, cleaned, re-seated connection, sorted |
nice easy fix.. |
