![]() | Home > Maintenance & Mods (L322) > MOT Fail - Park Brake Strip required |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
I should think they mean stripping down the whole parking brake at the disc/drum area and freeing it off. As I posted recently, very few people who drive autos use the hand break, preferring to put the vehicle in park when stopping at lights ext, hence they seize up. |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
My MOT guy advises using the parking brake every time you use the vehicle, saves all the hassle of components seizing |
Thanks. However, every time the car is used and brought to a stop, the foot brake is applied, neutral selected and the park brake applied. Only after it has secured itself and the car is "parked up", P is then selected before the ignition is turned off |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
That would be about right everything seems to be a maintenance issue. |
