![]() | Home > Technical (L322) > Rear Wash Issue |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
Can you hear the pumps running when you push the wiper stalk forward?
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
the headlight washers will only work with the headlights on and something like every fifth squirt of the window wipers the headlights get a squirt.
Cloned earl Member Since: 28 Jan 2014 Location: Earls Colne Posts: 12 ![]() ![]() ![]() |
Have a look here for the rear wash/wipe issue
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
I had a little time today so did a bit test work on rear wiper. The correct feeds and switched earths are as they should be, I was surprised to find the rear washer pump is switched from the rear wiper motor I can only presume the motor or ecu is the problem. |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
I had no washer on the rear, but others were working. This is how I fixed mine:
