Home > In Car Electronics (L322) > Handsfree Phone Microphone - Which Part - Other Suggestions
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
The quality of the calls on my Handsfree deteriorated a few weeks ago. I have an updated Bluetooth module fitted and all was fine when first fitted. I had fitted my PURE DAB and initially thought that maybe this was causing interference, however, I have removed this and still the phone quality is poor.
I have tried a couple of iphones 4, 4S, 5 & 5s as well as a LG phone and all sound similar. I can hear the caller fine and the phone works and connects as it should. However, the person I am calling says that they can hardly hear me and it sound like I am under water/there is water running over me. I have been on the receiving end of calls made as a test and confirm what they hear is very poor.
As the problem seems to be only with the outgoing sound I was thinking of changing the Microphone for a new or updated unit. The incoming sound is clear and of a good volume
Anyone able to confirm which is the best microphone (assume it is the round thing in the overhead front console), I have found these two alternatives:
Range Rover Long Phone Microphone
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...2336c44ea6
Range Rover Round Mircophone
[/img]http://www.ebay.co.uk/itm/Range-Rover-2002...3cdd2f913e
Not sure if these would work or if there is a better unit to try.
Also any other suggestions of what could be wrong if not the mic. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #247748 12th Mar 2014 12:47pm
rej
Stan, Got the following notification that you had commented;
Quote:
Hello,
stan has just replied to a topic you are watching entitled "Handsfree Phone Microphone - Which Part - Other Suggestions" at fullfatrr.com.
NOTE: You cannot reply to this message using your e-mail program (or e-mail service) as this will not send a message back to stan. You must use the fullfatrr.com site to reply to this message via this link: http://www.fullfatrr.com/forum/viewtopic.php?p=247753#247753
This topic is located at: http://www.fullfatrr.com/forum/viewtopic.php?p=247753#247753
Here is the message that has just been posted:
i'd try one of these,
[img:523:456:a4cf5a0be1]http://www.fullfatrr.com/gallery/albums/userpics/10672/Capture~179.PNG[/img:a4cf5a0be1]
Mr. Green
There also may be other replies, but you will not receive any more notifications until you visit the forum again.
If you no longer wish to watch this topic you can either click the "Stop watching this topic" link found at the top of the topic above, or by clicking the following link: http://www.fullfatrr.com/forum/viewtopic.p...atch=topic
Martin
fullfatrr.com
But does not show on the thread and the links don't work??? Is there a technical problem with the forum? There is a difference between knowing your sh!t and knowing you're sh!t
Post #247786 12th Mar 2014 4:16pm
it was a funny which i subsequently decided wasnt... ... - .- -.
Post #247787 12th Mar 2014 4:28pm
GraemeC
Oh, I don't know, quite funny Mr. Green
http://www.fullfatrr.com/gallery/albums/us...re~179.PNG 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #247792 12th Mar 2014 4:54pm
damn you Graeme... Embarassed Laughing ... - .- -.
Post #247794 12th Mar 2014 4:58pm
rej
Had something similar in the 80's to support my NEC phone on my shoulder as it was so heavy to hold but worked great as handsfree especially as the calls were kept short due to the high cost per minute 33p to 50p per min in 1989.
Back to the original post anyone know what mic is best if indeed this is likely to be the problem. There is a difference between knowing your sh!t and knowing you're sh!t
Post #247810 12th Mar 2014 6:08pm
rej
Still need help to try and sort sound quality on the hands free. Mic replaced and no difference. Also removed Pure DAB and aerial in case it was causing interference but again no improvement. There is a difference between knowing your sh!t and knowing you're sh!t
Post #248688 16th Mar 2014 11:16pm
rej
any ideas on what could be wrong or ways to try and test.
I have fitted new mic and no difference and I have the updated Bluetooth module in the boot that was working fine abd shows no signs of water damage etc.. (was a replacement module that was updated).
Problem is only with outbound sound quality. There is a difference between knowing your sh!t and knowing you're sh!t
Post #249234 19th Mar 2014 8:38pm
Bushells
Australia 2009 Range Rover Vogue TDV8 Rimini Red
I had the same issue. Pull the mic out stuff the cavity with packing felt/sound deadner and put it back in. seems ok now.
Post #249750 22nd Mar 2014 5:19am
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Excuse my ignorance but is the mike in the light unit in front of sunroof. I have new Bluetooth unit and all has been working fine but last day or two, I can hear callers but they can't hear me. Have tried all the normal master resets but the lack of microphone carries on. Previous to replacing the module, others said my voice was very quiet or distant but this improved when new module was fitted. TDV8 Vogue SE 2009.
TDV8 Sport. Gone. Loved it but it didn't love me!
Other toys in the cupboard.......
Post #249788 22nd Mar 2014 12:18pm
^ why ask here? i thought we were all knobs according to your posts on the RRS forum.. ... - .- -.
Post #249814 22nd Mar 2014 2:10pm
rej
Thanks I will give it a try and see if it makes any difference. There is a difference between knowing your sh!t and knowing you're sh!t
Post #249826 22nd Mar 2014 3:47pm
Simple1
Think you just proved my judgement call......... Rolling Eyes TDV8 Vogue SE 2009.
Post #249829 22nd Mar 2014 3:54pm
