![]() | Home > Technical (L322) > Td6 battery |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
Your car should start quite happily with a 95Ah battery, the 110Ah version just gives you a bit more reserve in colder weather.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
My genuine Land Rover battery is 110 Ah, and I'm pretty sure thats what it says in the manual.
Surprisingly the Vehicle Handbook quotes the battery size as 90Ah or 110Ah.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Is this a key not turning issue as opposed to a battery issue ? .
joebenz Member Since: 14 Dec 2013 Location: United Kingdom Posts: 9 ![]() ![]() ![]() |
He tried disconnecting the battery and resetting it the key still wouldn't turn. When he used a bigger battery he had in his van the key turned fine? Land rover quoted me £212 to supply and fit a new battery and they say it should be a 110v. |
I'd just go with the supply bit, and fit yourself..........at that price 2011 Range Rover Vogue SE 4.4 TDV8
As others have said, you should be fine with a 95Ah battery (if you manage to find a 110V battery and install it, you'll be having other problems |
