Home > Maintenance & Mods (L322) > transmission oil/filter change
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
hi, has anybody used the britpart filter on a td6 with gm box,i am going to change the oil and filter and was wondering the best filter to use
Post #248429 15th Mar 2014 11:23am
Best filter is a genuine Land Rover filter from Dan at Duckworths... Thumbs Up
Post #248442 15th Mar 2014 1:06pm
cowman
i have sent a email to duckworths but had no reply yet.
Post #248516 15th Mar 2014 10:09pm
Not sure on the td6 box but the genunie part on the 6hp26 on the tdv8 is a filtrans unit. Gen wasnt expensive from dan. There is nothing that can't be fixed with a hammer😜😜
Post #248524 15th Mar 2014 10:39pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
oe filter for the gm box is filtran, last time i priced one from lee at duckworths in kirton was over £100. heres a link to some one selling the original filter and gasket for half the cost.
http://www.ebay.co.uk/itm/261372667442?ssP...1423.l2649
just checked rimmers for a rough cost to see if they have come down since i last priced them and it would seem they have, 75 including the vat retail now.
Post #248537 15th Mar 2014 11:34pm
cowman
thanks for your help i will buy the filter on ebay,noticed they do the oil as well in a kit ,is it dextron 111,is this the right oil
Post #248622 16th Mar 2014 1:28pm
arron
after i had my gearbox rebuilt the guy who did it condemned the type of oil gm specified and said its only a standard dexron 3 and should really be a full synthetic instead, since the rebuild i run mine on the oil he recommended and to date is nice and smooth. although it should be as it only been on just over a year, only time will tell. if i where you i would be inclined to get some full synthetic dexron oil and flush it a few times then keep it on the good stuff, synthetic oil in my opinion can only help the gearbox and hopefully keep it trouble free.
Post #248701 16th Mar 2014 11:50pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Shouldn't oil be Dextron VI (6)
Post #248710 17th Mar 2014 4:54am
cowman
i thought dextron V1 was for the 6 speed box,millers recommend millermatic atf sp lll ws code 6213, this oil is getting to be a minefield.
Post #248729 17th Mar 2014 10:14am
33CHINACARS
This is the correct oil. Texaco ETL-7045E. But from a list that was about some time ago Dextron VI can be used if licenced by GM. Dextron VI superceeds all previous Dextron's ( III, IV etc )
Post #248786 17th Mar 2014 4:30pm
cowman
changed the oil and filter today,thanks arron for the filter link ,i used millers oil ,i rang there technical department and they had a choice of 2 ,the job was really easy took about 2 hrs .
Post #249864 22nd Mar 2014 5:55pm
