![]() | Home > Technical (L322) > windscreen trim clips |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
if you are talking about the vertical black trim then it it clipped in place and then there are 3 (?) plastic rivets on the rear edge on the door side. You can get a replacement clip set from LR to re attach the panel as it needs to come off for a windscreen replacement. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
If it's the a pillar trim, I got some more clips for mine, but when garage man was replacing them, the receiving bits in the body itself dropped down the structure or moved, so the rivets are loose. Trim seems fine though........ 2011 Range Rover Vogue SE 4.4 TDV8
