Home > Technical (L322) > ICE not working after refueling
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Here's a conundrum. After the last two fuel stops the ICE had packed up. All the services appear on the TFT screen, but no sound and the phone doesn't work either. Leave it a while, drive on to destination. On restart, everything back to normal. Any got any ideas?
Post #251805 31st Mar 2014 8:56pm
i'd start with the battery, make sure its fully charge and holding its charge.. ... - .- -.
Post #251806 31st Mar 2014 8:57pm
Andy S
If the battery was a duffer, surely it wouldn't fire the ignition? Also, lights windows a/c all work as normal. If the battery wasn't holding a charge, then the car would never start as I only use it about once a week on average.
Post #251816 31st Mar 2014 9:51pm
if there's a slight degrade in available power then not all the ecu's fire up and the ICE is regarded as non essential so all the power goes to the start up sequence..
thats why when you've driven for a bit and charged up the battery the ICE will fire up on restart.. ... - .- -.
Post #251820 31st Mar 2014 10:05pm
Andy S
I'm still not sure about that Stan. The car has only done this after the last two refuellings. At other times it doesn't happen. It sits for days on end between uses - some times a week or more, so if the battery was on the way out, surely I would have had problems starting after such a prolonged period of inactivity. I don't though; it fires first time on the button. A real mystery! I've posed the question to the techies at the supplying dealer and I'm waiting for their reply.
Post #252733 4th Apr 2014 5:08pm
that is strange...something is contributing to this problem when you fill up, static maybe? ... - .- -.
Post #252739 4th Apr 2014 5:56pm
