![]() | Home > Maintenance & Mods (L322) > Puddle on driver's door mat after car wash visit |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
I went through my local car wash today and was shocked to find a small puddle of water on the driver's rubber door mat afterwards. I didn't notice it forming while going through the wash, I only saw it on getting out to use the vacuum cleaner afterwards. The carpet underneath was dry. No dripping was visible but I think I felt a bit of damp along the join where the lower dash covering (below the steering wheel) meets the black covering further down above your shins. The puddle was just below and in front of the brake pedal, which was also dry.
Blocked sun roof drains ? if so do not use an air line to clear them but use some strimmer cord and work from the bottom up |
Do the drains run down to driver footwell area? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
If they are blocked the water will , the drains run down the pillar trims and end up under the car . Sorry I can't tell you exactly where because I have never had to do it but a quick search will reveal all . 2008 MY Supercharged
You mean this tube (centre)?
Checked the wiper tray drainage holes and the left one, in the photo above, was completely blocked. The right one was clear. I hooked out the dried-in dirt and now water falls through the tube onto the ground on both sides. The next trip to the car wash will show if that stops the leak into the footwell... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Went through the car wash last week and there was no leak into the driver's footwell. Looks like clearing the wiper drainage hole did the job |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
That was a nice cheap fix then.... Pete
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 217 ![]() |
Carwash = bad! |
