Home > Technical (L322) > 4.4 TDV8 Engine Remap
Lord Gnome
After much consideration and flirting with 5.0 S/C I picked up my 2011 4.4 TDV8 Autobiography Stornoway Grey two days ago and still enjoying the buzz. My first RR and it's a stoater.
Has anyone remapped the 4.4 and if so was it worth the expense? Not bothered on a power basis as there's plenty of grunt, but I'll be doing 25-30k miles a year so any improvement in mpg could make it worthwhile in the long run. Had a lot of 'advice' from people based on hearsay but would like to hear from someone who's done it.
Post #253784 10th Apr 2014 10:01pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Not done it but be aware that the gearbox torque limit isn't much higher than what the engine can deliver in standard tune. 4.4 TDV8 Vogue Baltic Blue MY11
Post #253789 10th Apr 2014 11:48pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
Agree on above as my mechanic also warned that the otherwise exceptional ZF8HP70 gearbox is not rated for much more torque than the standard 700Nm or whatever Lbft... He expalined that ha has seen gearbox failure at remapped/retuned 4.4 TDV8 vehicles. 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #253796 11th Apr 2014 5:43am
And also if you still have any kind of Land Rover warranty be aware they take a very dim view of Re-Mapping and I believe it's very obvious if a 4.4 TDV8 has had it done . The results are stunning but a few thing to consider here . 2008 MY Supercharged
Post #253802 11th Apr 2014 8:29am
