Home > Maintenance & Mods (L322) > Tyres - which wear first? front or back?
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Generally,
Which wear fastest?
I have 5mm at front and 8/9mm at rear so I am thinking about rotating the tyres and then change all 4 next year...that is, if the fronts wear the most!
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #21768 7th Jul 2010 6:12pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
I wear my front ones a lot quicker than the back despite it being a four wheel drive.. I tend to find the corners and roundabouts seem to remove most rubber Wink
Post #21771 7th Jul 2010 6:17pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Passenger front wear quickest generally
Post #21785 7th Jul 2010 7:39pm
EDWARD757
As suspected, Thanks.
Now how to rotate the tyres without ending up with a RR on my head!
'03 BMW M3 - SOLD
Post #21795 7th Jul 2010 8:23pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
What's peoples thoughts on this? Leave the NSF tyre on (and take the wear) therefore saving other tyres, or rotate wheels, to even out wear?
Seems a shame to ruin all four tyres, on the outer edges.
I suppose the tyre (if not directional) could be turned, therefore wearing on both sides, evening out the wear on the one tyre. Question
Post #29643 28th Sep 2010 8:55am
Ed
easiest way is to jack one side front up, stick a axle stand under there then jack up the same side rear..do one side then the other,,btw dont try and use the supplied scissor jack, its pants..use a trolley jack. ... - .- -.
Post #29644 28th Sep 2010 9:00am
firstly i would be tempted to have a four-wheel alignment check done to make sure the its ok...you could turn on the rim so that the worn edge runs out on the other side ,it all depends how bad it is .. ... - .- -.
Post #29645 28th Sep 2010 9:03am
Richcl
2-3mm over 7K of motoring (on the one edge). It's not to bad, just noticeable
Post #29657 28th Sep 2010 9:40am
Vogue
mine always seem to wear out all at once whether they are Michelin Goodyear or Vreds - not many roundabouts or city driving where I go though...
Post #29664 28th Sep 2010 10:17am
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
this one wears the right front first i guess Whistle
 2002 td6 vogue, 06 supercharged facelift
Post #29748 28th Sep 2010 7:03pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
At least that one is not on craptinentals otherwise it would wear the shoulders off both fronts even like that 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #29753 28th Sep 2010 8:03pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Rolling Eyes Thumbs Up
Post #29754 28th Sep 2010 8:07pm
Richcl
Interestingly I just had some tyres changed to different rims, the tyre fitter put the tyres back on, with the more warn side on the inside of the rim.
May have been coincedence of coarse.
Post #29822 29th Sep 2010 2:33pm
delamo
Nice idea Richcl - but not only are the Craptinentals that Tim referred directional - the outside edge is indicated on each tyre (Pattern of manufacturers script, Tyre size etc. is different on the inside/outside wall).
Post #29824 29th Sep 2010 2:40pm
Richcl
Oh yes, didn't think of directional (My tyres are uni directional)
Post #29825 29th Sep 2010 2:43pm
