Home > Technical (L322) > HELP: so many faults with IDD: when will car explode?
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Hi,
IDD Tool arrived and got it running (Thanks to Patrick from GAP!).
Did adjust the ride height: perfect guidance with the manual!
But.....reading faults gave me some heart attack Sad I got sooo many faults and as I don't understand most of them I hope you experienced L322 IID Tool users are willing to help me to cure from my heart attack Question
Here I have a list of faults found (I didn't clear a single one of them because I first want to know what it is): Bow down
ABS 1/A Temporary System Deactivation
ACM Audio System 1/4 1UA03 Vehicule Configuration Parameter
2/4 U2003 Fibre Optic Communication Bus
3/4 U2003 Fibre Optic Communication Bus
4/4 u2003 Fibre Optic Communication Bus
ATC Heat Cool 1/1 30 Air Quality Sensor line fault
BPM Body Processor 1/2 59 Driver door Central Locking Mechanism Broken
2/2 6F Rear Passenger Door Window Up Telay: Short to Ground
HID Left Headlight 1/2 C-D2S/ R-light is off
2/2 2A-Ignition Voltage < 7,5 Volts
HID Right Headlight 1/2 C-D2S/ R-light is off
IP Instrument Pack 1/5 BD-EBV function fault received from ABS ECU
2/5 BF Instrument Pack Checksum Incorrect
3/5 EF-N0 TXU1 received from transferbox ECU
4/5 11 Acoustic transmitter fault
5/5 CE- Ambient Temperature Sensor fault
LCM Light Control 1/ +17-Dimmer potentiometer open circuit
2/ +56-Injection system fault
3/ +57-Air Suspension Active/inactive
4/ +59-Transmission Emergency program fault
5/ +5B-Washer fluid level fault
6/ +5F-Check coolant fault
7/ +7A-Front left sidelight defective
8/ +7B-Front right sidelight defective
9/ +7C-Front left direction indicator defective
10/ +7D-Front right direction indicator defective
11/ +7E-Front left foglight defective
12/ +7F-Front left foglight defective
13/ +80- left high beam headlight defective
14/ +81-right high beam headlight defective
PATS Antitheft 1/4 F – Power -on Resee
2/4 3-Key 0 – Random code tolerance increased
3/4 13-Key 1 – Random code tolerance increased
4/4 E – Engine control moduleRandom code XOR error
RDUM Remote drive 1/1 09A99 – Unknown
TBOX Transfer case 1/4 52ED-instr2 lost from CAN (OX52ED)
2/4 52F2-instr3 lost from CAN (OX52F2)
3/4 5223 – Noise on actuator signal (OX5223)
4/4 5212 – Battery undervoltage (OX5212)
TCM Transmission 1/1 85-Can bus transferbox timeout: General fault
Tell Cell phone 1/2 B1Aoo-Control Module
2/2 U3000 – Control Module
TMC Traffic Message 1/1 B1A56 – Antenna Circuit
Post #254624 15th Apr 2014 8:47pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Scrap it and buy a new one Thumbs Up
I would just do a full reset, then reinterrogate at a later time to see if any reoccur, that way you can narrow down to any potential issues.
Ps, mine had much the same quantity wise with many related to non issues like audio system GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #254625 15th Apr 2014 9:01pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Wow just a few then 1994 softail full stars n stripes custom harley davidson
Post #254632 15th Apr 2014 9:44pm
those faults are probably logged since 2005 so as suggested ,clear them and see what you have in a weeks time.. ... - .- -.
Post #254633 15th Apr 2014 9:54pm
GraemeC
Humm, this one looks suspicious.....
If it actually means your battery isn't supplying the correct voltage, then knowing the multitude of faults people seem to get from a degraded battery, I'd sort the battery, clear the faults and then see what you have in a weeks time....
Can anyone who knows about ID tool fault reporting give more info on this particular fault?
Also, as Stan said, if they are all the faults logged since 2005 I would not worry Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #254643 15th Apr 2014 10:46pm
Showing its reliability if it has not been near a main dealer or indie with diagnostics for 9 years (unless they don't clear faults on plugging in?)
As suggested, clear them all then check in a week or two to see what comes back. Even then some of them can be safely ignored, e.g.
IP Instrument Pack 1/5 BD-EBV function fault received from ABS ECU << this will keep coming back!
Post back your output in a week or so Thumbs Up .
Post #254647 15th Apr 2014 11:09pm
ebajema
As Graeme and Stan say, just reset and put a brand new battery in. Battery low voltage indeed gives you the impression the car is going to disintegrate in seconds Smile. The ECUs' just can't handle lower voltages and start thinking the world is coming to an end NOW.
It is probably caused by the signals from a number of sensors coming back with a slightly too low voltage on their signal, due to the low input voltage from the battery and then the ECUs see that as something wrong with whatever the sensor is measuring, hence the fault. MY 2010 5.0 SC Galway green and sand interior!!
Post #254648 15th Apr 2014 11:11pm
supershuttle
Clear the faults using the IIDTool then see what comes back. I'd hold off on the battery for now until you're sure it needs a new one, yes it was flat once - but we've all been there Very Happy Geoff
Post #254670 16th Apr 2014 7:35am
Rangie4fun
Thanks for your replies and curing me from my heart attack Laughing
Just ckecked the battery yesterday and it was 12.28 V so probably it had its best time, but I will leave it in now. Today I'm going to clear the faults and then keep the fingers crossed for the next week or so Shocked
I'll keep you posted with the results
Post #254801 17th Apr 2014 7:46am
Rangie4fun
a bit late....but finally a post with the results! May we have your votes please Laughing
cleared all the faults, and did check them regularly: most of them where goone for good, but some of them kept coming back Crying or Very sad
So the suspected battery was checked and checked again and also the charging system: system seemed to be OK, but not the battery. Also couldn't charge the battery with a charger. So decided to fit a new battery. Varta Silver Dynamic arrived today and fitted as per Wikii (worked out perfect). Used the car after that (5-6 times starting up!) and didn't get the HDC fault as I used the car this evening Mr. Green
Think that these faults were due to the battery.
Thanks for your help you lovely FFR forum! Thumbs Up
Post #261979 28th May 2014 10:04pm
Good result, as the faults have gone, so anything which now may pop up is a new relevant fault. There is nothing that can't be fixed with a hammer😜😜
Post #261987 28th May 2014 10:33pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Post #261990 28th May 2014 10:40pm
Rangie4fun
Aaaarghhhh, battery drain Big Cry
Think the FSR is faulty Question
Post #262609 1st Jun 2014 5:32pm
