Home > Maintenance & Mods (L322) > Worn spokes
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Worn spokes
The spokes were worn and rubbed on the corners so I thought surely these would paint Cool so after removal of the steering wheel which is a doddle the hard part was prising the spokes apart which was a little tricky after 10 years together Neutral finally apart you'll find they've got a rubbery film over the fronts so sand down then a bit of wet and dry, wipe with cloth leave to dry for five mins, I put the primer and silver cans to warm up standing in the sink of hot water to give a better spray, after three coats of aluminium and two lacquer leave to dry for an hour then press back onto the steering wheel and bobs your uncle at a fraction cost, you could wrap if you desire as well Thumbs Up
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #255894 24th Apr 2014 12:15pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Look good.
I have the replacement spokes to fit just haven't got round to taking the airbag off to fit them, plus I can't decide on a new steering wheel as well. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #255896 24th Apr 2014 12:24pm
Looks good, top job... Pete
-Click here for Thread-
Post #255901 24th Apr 2014 12:52pm
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
I wish I had your patience, I will add the trims from powerful when I get the time
Post #256147 25th Apr 2014 5:55pm
Flashman
Which paint did you use for the aluminium/silver finish? Tom
Current Drive
Previous Drives
Post #256215 25th Apr 2014 8:27pm
