Home > Technical (L322) > Can use MY02 - 05 Towbar armature on MY 06 - 10 FF
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Well, bought a Westfalia (original RR) tow bar from the bay of e. A colleague of mine at work, who has an '03 FF spotted the listing, which was definitely for 06 on vehicles, complete with the correct part numbers, so he thought it would be no good to him, but would suit me. Very Happy
Anyhow, managed to win the listing, and went to fit it to my FF on Thursday. Only problem was, once I had stripped my FF down, and got the tow bar out of the shed, it became apparent that it was the earlier type, as the exhaust mountings were different. Big Cry
Having looked at the differences however, and examined the 2 'crash bars' you remove from under the FF prior to fitting the towing armature, I thought if I angle ground the 2 right angle brackets that the exhaust mounts to from these, I could just put them under the front mounting bolts, and I would be OK.
Rang Westfalia, and they confirmed that this was in fact the case - you can use the early armature on the later car by removing the exhaust mounting brackets from the crash bars, but the late armature will not fit the earlier vehicles. Thumbs Up Thumbs Up
Sorry, pic's I had taken have disappeared inside my 'phone somewhere, and I can't find them. Big Cry Big Cry 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #256334 26th Apr 2014 1:45pm
i think it is all down to the exhaust brackets , if you can 'fettle' them then it should be ok.. ... - .- -.
Post #256337 26th Apr 2014 1:50pm
Full Fat Ray
Yes Stan, is fine, all fitted now OK, Thumbs Up just thought I would post on here in case the info is helpful to someone else. Very Happy 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #256345 26th Apr 2014 1:58pm
Thumbs Up ... - .- -.
Post #256357 26th Apr 2014 3:32pm
Dolphinboy
Ray, PM sent.
Post #256466 27th Apr 2014 12:53pm
