![]() | Home > Technical (L322) > Air susp inactive ..... |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
When I had this issue it had to be plugged in to reset it. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i wonder if they knocked the abs sensor when they did the alignment?
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Thanks fella |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Most likely the steering angle sensor will need to be re-calibrated |
Well the ff will be going back Monday for them to sort it out, if they can! and I'll probably get an iid tool too you never know when that bong rears his ugly head |
Just thinking today while gardening.. Was wondering if I should do one of 3 things
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
If the steering wheel isn't set straight ahead, or in the position it was before, after tracking the air suspension inactive message will show. Had the same thing when I replaced a track rod end. Once I had the track rod end set correctly the steering wheel was again centred and the fault cleared.
Your first two options, whilst time consuming for you, are free |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Option 1 for me. This has almost certainly been brought on by the fact that the steering wheel is not centred when you drive in a straight line. It's one hell of a coincidence if not! The fact that they don't have LR diagnostics is not your problem. If it were me, I would very politely but firmly be parking (literally!) this in their court.....
Just one point, taking the steering wheel off and putting it back on straight will not cure the problem.
Up date number 1
Tip of the day
Up date 2 and final chapter ( I hope |
