Home > Maintenance & Mods (L322) > DANGER! CAUTION!!!
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
DANGER! CAUTION!!!
Since I love this community allready so much (but not so long) I do not want to loose any of you guys Big Cry who give such a fantastical advice to all of us Smile
So a well meant WARNING to any one who will crawl under the car to do some fixes.....NEVER EVER do this without axle stands!
As in several threads advised "just put in off road height and you can go under the car" is absolutely a No Go. As we all know we have air suspension and it is possible that such an airbag can burst at any time. Don't take that risk for just saving a few quit on axle stands. Just keep around and have fun with your FF Mr. Green
Post #256269 26th Apr 2014 7:34am
The supplied scissor jack can also not be trusted, one of mine once collapsed with the car on it, luckily i'd just finish doing up the wheel nuts and I wasn't under the car. Shocked Discovery 4 HSE
1993 90 Tdi
Post #256271 26th Apr 2014 7:47am
both are good advice Thumbs Up ... - .- -.
Post #256284 26th Apr 2014 10:11am
mjdronfield
Without sounding stupid, and I posted some time ago about my axle stands - where do you tend to put them ?
I got a pair strong enough to hold the Rangie, but the contact points seem to be just that - a point, and the instructions say to have the car "in the cup", but there is no "axle" on the car (obviously).........
Some suggest to put them on the jacking point, but thats still not "in the cup".
Do I need to get stands with a flatter top ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #256295 26th Apr 2014 11:11am
Rangie4fun
Hi mjdronfield,
In contrary, this is just a very clever question! On any other car it's a very good instruction to put the axle stand under the axle or as you did in your picture, under the arm. But not on a FF with air suspension! The arm (or axle) is under load of the road spring and thus holds up the car. And for the FF that's an .....air spring (which can burst or any other failure in the system leading to a prompt flat one). And if so your FF can still come down on you, despite the axle stand. Crying or Very sad
So for the FF: place your axle stand under the body where ever it can hold the car's weight: i.e. the jacking points are absolute save and also the parts of the subframes that are attached to the body (you can have a look at the pictures in the WIKI Td6 replacing front ball joints: dan_uk_1984 has placed them under the front subframe tube which is save).
The extra tip I would suggest: place a rubber strap between body and axle stands so it never can slip off.
Post #256438 27th Apr 2014 9:31am
