Home > Maintenance & Mods (L322) > Tailgate release button rubber cover
Googsy
I bought one of these recently the rubber button that fits into the existing tailgate release button space. I have to say I prefer the tailgate release without the button fitted as when using it seems to become loose and I invariably have to keep refitting every time I use it Evil or Very Mad Is this how they are supposed to be ? Maybe I have fitted it incorrectly but I can see under the button there are 4 retracting clips that hold in place so a bit stumped thanks. Thumbs Up I have removed it for the moment due to frustration it does look nicer when fitted compared to plastic button. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #256528 27th Apr 2014 5:11pm
on my td6 the cover fitted on and stayed on, but i'm having the same problem as you on my new FF.....the cover seems to be slightly over lapping the trim and gets caught very easy and then comes off..
i'm toying with the idea of glueing a thin membrane of sorts under the trim to cover the button.. ... - .- -.
Post #256533 27th Apr 2014 5:41pm
Googsy
Good to hear was thinking maybe a thin bead of clear silicone Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #256543 27th Apr 2014 6:34pm
Strange Conor , have had the rubber fitted for near on two years and never once has it fell off .......
And the remarks Whistle Whistle ====================================
Post #256548 27th Apr 2014 6:56pm
mjdronfield
You have to use it for it to fall off Laughing
Mine was the same, you really have to make sure the rubber tags are under the trim on the tailgate.
Something with a wide flat blade to push them under when fitted...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #256554 27th Apr 2014 7:11pm
i took the trim off to fit this cover properly but it still falls off..craig noticed it missing when doing my oils and he suggested some glue/silicon , might be the way to go... ... - .- -.
Post #256592 27th Apr 2014 9:47pm
Mine did keep falling off, i gave it a good wallop and its been fine since. Whistle There is nothing that can't be fixed with a hammer😜😜
Post #256593 27th Apr 2014 9:52pm
