![]() | Home > Technical (L322) > Air Suspension Fault Followed by Explosion |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
Not an expert, more knowledgeable chaps will be along soon.......
an-drewm Member Since: 29 Mar 2014 Location: Cornwall Posts: 10 ![]() ![]() ![]() |
Thanks,
That's where my knowledge ends I'm afraid. Never had the exact issue. The system wouldn't know it'd put too much air in, as it didn't get a valid reading.
I read that there is a safety feature to prevent too much pressure going in which is why I think something else might be wrong. |
We had an Audi Q7 and the other year, after 4 tyres were fitted at a well known company, the compressor started to run and run and run following which the compressor exploded and the front end of the car/ air suspension dropped down, resting on the front tyres, rendering the car undriveable. There were - post explosion - loads of little white pellets all over the driveway. That cost over £2k to fix, albeit under warranty.
Suggest you inquire at the garage you took the car to, and ask them exactly what they did. They must have had the car up on a lift at some point? Perhaps the lifting caused the height sensor to jam or even turn (difficult to imagine how?) What position is it in now, same as the other side? Does it look the same?
Considering the age of your car the airbags may have been quite weak already. On mine (the 4.2 built 05/05) the front bags went 2 years ago. Completely cracked on the "fold over" all the way around. Pure old age plus hot climate I guess.
Thanks. The garage claim it wasn't lifted and all work was done on the ground. I still can't work out why the rear only would lift to that height. If the rear height sensor was damaged then surely the ecu would detect no height change and fault then rather than pump to the point of going bang. |
That was my thought but nice to get a 2nd opinion. |
Yes, I agree, logic would dictate that, but its a FFRR ![]() ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
