Home > Technical (L322) > Rear Tail Lights
DMRR
Rear Tail Lights
Swapped all my lights to LED bar the rear fogs - they seem :
1. To be in the wrong place according to the manual.
2. To be dual filament.
Can someone confirm the rear lights on a 2007MY non-sc light top and bottom in the 'red' area on normal 'lights on'????? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #257277 1st May 2014 9:02pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
In the 'Red' area of your tail lights, you will find 2 lamps.
They are both dual filament.
The low wattage filament (5W I think) of BOTH lamps comes on when you have the tail lights illuminated.
The high wattage filament of the LOWER lamp comes on when you select rear fogs.
The high wattage filament of the upper lamp is not used.
Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257278 1st May 2014 9:11pm
http://www.fullfatrr.com/forum/topic22712....led+lights
Thumbs Up ... - .- -.
Post #257281 1st May 2014 9:18pm
DMRR
My 'top' one is one with two 'contacts' on the bottom, my lower is a single contact.
Can we confirm both are on with main lights on? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #257282 1st May 2014 9:24pm
both should illuminate on side/main, only one will illuminate brighter for fog.. ... - .- -.
Post #257283 1st May 2014 9:26pm
DMRR
Ta - it does but the manual for my vehicle is wrong! Hey ho Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #257286 1st May 2014 9:32pm
DMRR
Did you know that if you switch DRL's on ... only one of them illuminates - most baffling! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #257288 1st May 2014 9:51pm
pld118
From memory DMRR my manual had them the wrong way around too. Turned my world upside down! Rolling with laughter
Post #257291 1st May 2014 10:00pm
DMRR
Excellent, not just me then!!! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #257292 1st May 2014 10:01pm
