I did have, the wiper arm need repositioning so it stops its sweep before it reaches the a pillar.
You may notice that the wiper is sitting slightly high at rest also.
1. Open bonnet
2. Remove plastic cover from wiper arm
3. Remove nut holding wiper on to the car.
4. You should then Be faced with an unusual shaped washer/spacer. Remove.
5. Remove wiper arm.
There is a lug on the wiper stalk, this needs to be reset one spline clockwise.
It is a pita to get off as it is liable to be seized on.
Chances are the screen has been replaced and the fitter didnt put it back on in the right place. There is nothing that can't be fixed with a hammer😜😜
