Home > Technical (L322) > Interior lights
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Interior lights
Hi chaps
I'm not with my 2003 vogue at the moment to check but tomorrow we are taking it to the local point to point meeting as it's my daughters birthday party 12 x 14 yr old girls Rolling Eyes they are bound to be in and out of it all day doors boot open about 500 times is there a way of turning interior lights totally off or should I pull the fuse and if so is it easy to locate which one
Cheers
Lee Thumbs Up
Post #257416 2nd May 2014 8:47pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
My FF is a 56, but i'm fairly sure yours will work the same, best thing would be to pop out and try this and see if it works for you. Thumbs Up
With the interior lights on (after opening a door and then closing it), if you press and HOLD the black button on the FRONT interior light for about 15 seconds, they will be turned off (includes footwell lights, puddle lights etc). They will remain off, even if the vehicle is locked / unlocked again, until you press the black centre button on the front light again (briefly). They will then revert to normal operation. Thumbs Up
Don't think there is any facility to do this with the lights in the loadspace however, so you will need to tell them (on pains of death Twisted Evil ) not to keep opening the tailgate. Mr. Green 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257422 2nd May 2014 9:11pm
mjdronfield
I've not seen a switch for them, not like the old days.
I know they time out and stay off after a period of time if a door is left open, about 10/15 mins with door open and they turn off. Don't think they come back on until the ignition has been cycled, but you'd need to test.
Thinking on, they reset if the car is locked and then unlocked, so that ain't gonna work for you.
Looks like you may have to pull the fuse, but looking in the workshop manual, it's not obvious which one and there are 2 or 3 regarding light modules......not too many pages in....
http://www.xtremelandy.co.uk/Manuals%20fol...r_L322.pdf 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #257424 2nd May 2014 9:19pm
mjdronfield
Full fat ray posted whilst I was typing.
Interesting to see if that works.
A bit easier than removing fuses.
I know you can stop the luggage area lights coming on under certain conditions with navcoder.......
Does the passenger compartment lights come on if you use the button on the key fob to open the tailgate only ? Don't remember.
Downside to that is you could end up with the keys locked in the car if someone puts the keys down whilst in the boot and then forgets and shuts the tailgate....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257426 2nd May 2014 9:25pm
mjdronfield
Right, just had a look in the manual, if you want to turn the lights on and off manually, briefly press the button for the main light in the overhead console.
If you want to turn off the automatic lights completely, hold the button for 3 seconds.
Repeat the above to enable the lights once more.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257428 2nd May 2014 9:34pm
Sparkylee
Thanks guys will try that in the morning Thumbs Up
Post #257433 2nd May 2014 10:34pm
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Unnecessary quote removed
Just wanted to say a big thanks as in the first week of having the car , all doors open and tailgate , next day went to start it up and was flat as a pancake.
Am constantly switching the lights of with the black button but after trying your trick it works Thumbs Up Bow down
No more worrying about flattening the battery Thumbs Up
My bad again , A big thanks to Full Fat Ray Thumbs Up
Post #257598 4th May 2014 12:57pm
