Home > Technical (L322) > 2003 Air Suspension, Driver Door will not lock, No Comms
adrian3824
2003 Range Rover HSE Td6 Zermatt Silver
hi i have a 2003 range rover td6 hse, the air suspension light has come on and also the drivers door will not lock with the remote(will do manually). also can not communicate via the diagnostics port to retrieve codes will read engine revs and MAF values but thats all. just tried fitting a new door lock and had no joy so its not that (£85 dealer cost).
With the air suspension there is no lights on the dial either but the compressor is less than 6 months old and works as put a temp feed to it.
looks like something is holding it off but i have downloaded rave and started to check the comms links etc to the EAS ECU and its ok. to say now i am lost is an under statement any help appreciated. cheers adrian.
originally posted in wrong forum
Post #22232 13th Jul 2010 4:03pm
