Home > Maintenance & Mods (L322) > Trolley jack or Air jack? |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
An air jack won't work on twin exhausts unless you plug one of the exhausts.... |
13th May 2014 11:32pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
3 tonne trolley jack 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
13th May 2014 11:38pm |
Trolley jack !! MY 2010 5.0 SC Galway green and sand interior!!
13th May 2014 11:59pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
If you mean the air jacks used for off roading then by time you've set up the air jack and pumped it up high enough to get a wheel off the ground you could have lifted it on a trolley jack and had the wheel off. OK for an emergency on soft ground but too cumbersome and slow for working on a vehicle (I tried mine at the weekend). If you mean professional air jacks with a proper compressor then they are pretty good but expensive and need a compressor. |
14th May 2014 1:06pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
You don't want to be under it, setting axle stands with an air jack, if it burst, or more likely slips out you'll have a Range Rover on your head....
14th May 2014 1:37pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Trolley jack every time.
14th May 2014 6:35pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Well trolley jack it is then. Thanks for the advice everyone Travelling around in circles again. |
14th May 2014 8:30pm |
Also got the clarke 3 tonne strong arm high lift trolley, works really Well and have just done the wheels on the disco this eve in about 30 mins, including climbing through the garage obstacle course to the back where the wheels were stored! There is nothing that can't be fixed with a hammer😜😜
14th May 2014 11:24pm |
+1 Northernmonkeyjones.
14th May 2014 11:32pm |
