Home > Technical (L322) > Nearside Mirror dipping problem
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
The dipping mirror function on my RR is not working. When selected the mirror constantly moves up and down and in and out a little. Confused Rolling Eyes
I don't/won't use this function however if it is an easy fix, I will do it.
So over to you guys, IS it an easy fix or should I just ignore it?
Post #259276 13th May 2014 10:03pm
can you fill your car profile in so we know what year/model you have. ... - .- -.
Post #259277 13th May 2014 10:05pm
iphs
Cheers Stan.
I have done that now.
Cheers
Post #259280 13th May 2014 10:09pm
mjdronfield
I'm guessing there could be an obstruction or something broken behind the mirror that stops it going to where it needs to, so it may restart the dipping process.
You can, as you prob know, move the left / right selection button on the top of the drivers door and it will disable the feature.
Prob need to take it apart for diagnosis.
As a side note, have another look at your profile settings as when it's all setup you have a little car symbol under your post count at the side of the flag.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259329 14th May 2014 5:19am
