Home > Technical (L322) > Shift motor and position sensor.
As a few of you may have read i have another leak from my 3.6 tdv8 transfer box, i spent half an hour under the car with a torch and a rag, i am now fairly sure that the leak is coming from further up the box not the new silicone seal, i wiped it all down and am going to run it a while to confirm later on.
There is evidence of leakage around the shift motor and the position sensor, it seems to be the top of the oil trail, there is no oil on the back front of the casing or drivers side, its all on the rear passenger side upper(has run round underneath too). I am assuming that it would be possible for the seals on these to fail as they are o ring type. The question is, is it possible to remove the shift motor and/or the position sensor without removing the transfer box? Cant find any reference to it in the trans box section of rave! Seems to be about enough room!
As they are at the top of the box im assuming that the box doesnt need draining!
Not thinking many will have done this.......but you never know.
Much bowing Bow down Bow down Bow down There is nothing that can't be fixed with a hammer😜😜
Post #259546 15th May 2014 7:02pm
not tdv8 but td6 how to, might give you an insight..
http://www.fullfatrr.com/forum/topic7204.html ... - .- -.
Post #259547 15th May 2014 7:05pm
Cheers stan, its a good write up but on the dd295 The motor is further up round the box with the position sensor above it, so its more a clearance issue really!
I will have a scour of rave and if i can find the method might have a go! There is nothing that can't be fixed with a hammer😜😜
Post #259550 15th May 2014 7:16pm
Right have cleaned it all up and degreased the area and taken it for a run, the drip has appeared at the bottom of the shift motor mounting face, difficult to see any higher, but definately from the seals round the motor or position sensor!
Slight result, but a new motor is £200 no seal kit available, and the sensor is £72. I wonder if its possible to just change the o ring on it....... I have a massive selection box Whistle
Otherwise its about an hour i would reckon to swap them, and i cant do he motor myself as it needs recalibrating aparently on the diagnostic...... There is nothing that can't be fixed with a hammer😜😜
Post #259748 16th May 2014 4:57pm
