![]() | Home > Technical (L322) > l322 OE SIDE STEPS NOT WORKING |
| PUPPYDOGS Member Since: 11 Nov 2013 Location: leeds Posts: 10
Hi, Just wondered if anyone can help me with my tdv8 which has oe side steps, the LH works perfectly but the RH stops out and only moves slightly when the door opens or closes.if I press the switch the RH will still not retract,the motor seems to be working so hubby says.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Mech stuck? Stone or stick wedged in somewhere? |
no nothing stuck checked already, hubby wondered if you can adjust the mechanism linkage ? |
