Home > Duckworth Parts > Key for 2002 L322
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Key for 2002 L322
Hi Dan,
Can you quote for a replacement key for an early L322? Have 1 that is functioning fine but don't want to get caught out should anything happen to that one.
Are the the old fixed blade style the only option or can you get modern flip ones to work?
Thanks
Post #261775 27th May 2014 11:16pm
Bagus
Bump.
Post #263188 4th Jun 2014 2:03pm
duckworthparts
Site Sponsor
Sorry Bagus only just seen this !
early type key would be £149inc vat, not sure on the flip key, think a few members have done the upgrade?? You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #263196 4th Jun 2014 2:42pm
Bagus
Thanks Dan,
What do you require from me to order the key and does it come back cut and programmed or what exactly am I getting for the £150?
Thanks
Post #263200 4th Jun 2014 3:01pm
duckworthparts
Site Sponsor
need chassis number and V5 document.
key comes cut, will need syncing with your vehicle though You can paypal direct using - www.paypal.me/duckworthparts
Post #263204 4th Jun 2014 3:28pm
Bagus
Thanks Dan. Sorry to drag this out but in order to sync is it just a case of following the steps below or do I need to go to my local dealer?
Syncing process
(1) Get in and close all doors. Turn ignition on and off quickly (to the first position) and remove the key (all within about 5 seconds).
(2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks*). Holding the key at your head level provides best results as the key sensor is in the side window pillar.
(3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
(4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again (presumably to the first position) to finalize.
Just want to make sure £150 is the total outlay before I proceed.
Post #263205 4th Jun 2014 3:36pm
