Home > Maintenance & Mods (L322) > 12v power source
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
12v power source
I'm likely to want to fit a phone holder to my car that incorporates a charger.
My normal power source is the cigarette lighter, and as that is close to the location that I will use it again makes sense... providing I can work out how to get to the connections on the rear of it... Any suggestions gratefully received....
Post #263012 3rd Jun 2014 6:08pm
Probably easier to do a piggyback fuse feed from the main fusebox in the glove compartment Question .
Post #263017 3rd Jun 2014 7:06pm
^+1 Certainly will. Thumbs Up
Post #263024 3rd Jun 2014 7:36pm
Behind the left hand side panel is all of the wiring needed for a phone kit Thumbs Up The loon running up/down has + - ACC & un-amplified front speaker wiring Thumbs Up
Post #263032 3rd Jun 2014 8:09pm
davidjpowell
I'd still have to find a negative/earth....
Post #263033 3rd Jun 2014 8:11pm
davidjpowell
Tell me more... Not bothered about the speakers but the + - would be helpful. Which panel is this?
Post #263034 3rd Jun 2014 8:12pm
Whistle Whistle Whistle
Post #263035 3rd Jun 2014 8:15pm
Between the heater controls and your passengers knee Thumbs Up
Post #263036 3rd Jun 2014 8:16pm
davidjpowell
Thank you..... Next (and hopefully last! ) question...
Am I correct in thinking that I somehow remove the side trim of the centre console, passenger side to get to this?
Just pull off?
Post #263040 3rd Jun 2014 8:28pm
One hidden torq screw by your passengers right toe! Then pull the bottom of the wood panel out (towards the passenger door) held in by the same clip as holds the door cards on, then pull the panel down towards the floor out of the top slider clip... It will then fall off onto the floor and "voila" Thumbs Up
Post #263042 3rd Jun 2014 8:33pm
davidjpowell
thank you!
Post #263050 3rd Jun 2014 8:53pm
Post #263055 3rd Jun 2014 9:00pm
This is where the wiring is, tapped in here for my Hidden CB, just enough room for its speaker too
Don't know why it's loaded upside down, bloody iPhone.... Pete
-Click here for Thread-
Post #263109 4th Jun 2014 7:38am
You can see the earth point as well far left or far right if you looking upside down..... Pete
Post #263111 4th Jun 2014 7:43am
Thats it sir Thumbs Up
Post #263112 4th Jun 2014 7:43am
