Home > Maintenance & Mods (L322) > Spray paint issue
corinthian99
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Spray paint issue
Feeling a bit bored and thought it would be a great idea to get some new side vents and colour code them - learn a bit of spray painting on the way, well seemed a good idea at the time. Duly bought some vents, range-rover paint/lacquer kit and some plastic primer. All was going thoroughly brilliantly until I thought "Not enough paint here. I know I'll nip down to Halfords and get a full can of base coat and lacquer". Oh dear, looked great and then at the final fence sprayed over the Halfords lacquer and left it to dry. Next day soft, day after still soft and lines appeared. Clearly not compatible. So, its sandpaper out time!
Question is can anyone reccomend a good brand of spray paint? Anyone had this issue before? Google is absolutely awash with different ideas. Oh and FWIW its zambesi silver that I'm after if that makes a difference.
Cheers
Post #264398 10th Jun 2014 10:29am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I have just sprayed up the bonnet vent, the spray used where from bay of e
Plastic primer used on steering spokes and bonnet vent as well as my PDC's and all is a nice coat
http://www.ebay.co.uk/itm/140726390913?ru=...479wt_1183
The MCB and titanium silver where got from these
http://www.ebay.co.uk/itm/350851787234?ru=...254wt_1183
hope this helps If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #264407 10th Jun 2014 11:19am
