Home > Technical (L322) > IIDtool BT - Excellent
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Bought myself an IIDtool BT and it is excellent and great service from Patrick in even the few days I have had it. Highly recommended. The only downside as far as I can see is it tells you what is wrong with the car....and now I will have to fix the darn thing Razz
AAM-Audio Amplifier (MOST)
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
IPC-Instrument Pack (HSCAN)
U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
TMC-Traffic Message (MOST)
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
TVM-Television (MOST)
B1A00-48 (2F) Control module - System internal failure - supervision software failure
Odd thing is the TV is working seemingly fine so really not sure what the last one is talking about. 2011 Stornaway Grey 5.0SC Autobiography
Post #264040 8th Jun 2014 6:03pm
the B1A01/2-13 (2F) Speaker 1/2 circuit - General electrical failure - circuit open refer to the mid range speakers , i have this and mine work ok..
the U0248-87 refers to the venture cam, again i have this error cos i havnt a cam.. ... - .- -.
Post #264047 8th Jun 2014 6:51pm
jonlewis
Thanks Stan,
I am wondering if the CCF has the Venture Cam enabled when the car has never had one. The last time someone plugged in the car was all over the place on CCF so maybe this is something that was missed.
I believe there is a fairly common fault on the TMC antenna and will do some searching on that but am fairly certain I have read posts about that in the past.
the IIDtool is a very clever bit of kit though, particularly with the iPad functionality. 2011 Stornaway Grey 5.0SC Autobiography
Post #264070 8th Jun 2014 9:53pm
my venture cam error comes up every time i do a scan and i dont even have the docking station .. ... - .- -.
Post #264112 9th Jun 2014 8:29am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
We’ve seen cases, including our 2007 RR, where wires under the passenger seat were damaged dues to rubbing on a metal bracket. Might be worth looking but it will require removing the seat.
Post #264224 9th Jun 2014 5:58pm
jonlewis
Hi,
In which error did you find the undersea cables causing an issue. I do know mine has had some work under there as the plastic cover has some damaged fixings.
Jon 2011 Stornaway Grey 5.0SC Autobiography
Post #264252 9th Jun 2014 8:10pm
PatGAPInnov
Site Sponsor
We were looking for something else but found out that this was related to our speaker issue. There are plenty of wires under the seats and they can rub on a metal plate or other if not routed correctly.
Post #264259 9th Jun 2014 8:38pm
