Home > Technical (L322) > Locking question |
In the CCF there is an option to switch the interior sensor off as far as I can remember. However, the dual click of the lock button used to indeed disable the interior sensor. On later model years that changed however, I think on the MY 2010 for example, the second press is superlock. Not sure if it also disables the interior alarm.
10th Jun 2014 2:36am |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Lol wish I could but because I am going to France I can't afford an IID tool, just had an inspection service too that wasn't cheap 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
10th Jun 2014 8:13am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
have a browse through the user manual, i'm sure the lock sequence is detailed in there.. ... - .- -.
10th Jun 2014 8:15am |
Thanks Stan, I did have a good read but it says press twice to deactivate interior sensors, but last time I tried it didn't hence I was wondering if it was something that could be changed or configured 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
10th Jun 2014 2:10pm |
Is yours definitely a 2009 model? Could it be a 2010 which was registered in 2009? I ask because they are different and I have the same issue you do. (Pooches). You can easily tell from the key, The early key has 3 buttons in a row and the later key has 4 buttons in a square layour 2+2 and then the triangle panic button
10th Jun 2014 2:18pm |
Yep it's definitely a 2009, Westminster was the limited edition before the facelift to 2010 style and has the three buttons only on key
10th Jun 2014 4:46pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
We have a 56 plate. There are 3 buttons on the key - at the top (nearest to the key blade), there is a large oval button with the 'Land Rover' logo on it. This button is used for locking.
10th Jun 2014 5:34pm |
i cant see this function on the ccf with my iidtool so i reckon its non-configurable.. ... - .- -.
10th Jun 2014 6:04pm |
Thanks Stan, that settles it then, I'm doing it wrong, maybe pressing too fast after locking or something odd. SWMBO is off to work in it now so I will have to play about later.
10th Jun 2014 6:50pm |
the manual says press again after 2 seconds and before 10 seconds....hope it works for you mate. ... - .- -.
10th Jun 2014 7:35pm |
Sounds like the remote needs a stopwatch added to it MY 2010 5.0 SC Galway green and sand interior!!
11th Jun 2014 6:04am |
