![]() | Home > General > Can a Fatty be this economical ? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Brim it to get the true figure. Some people find little difference between the computer and the true values, but mine is way optimistic, and also inconsistantly opimistic. I average 30mpg from the computer, but 27-28 true. The best true value I've had was 30.3 mpg. Mine hasn't been remapped, but it's had the EGR delete. |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Just had 32.9 out of mine on a long run td6 |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 258 ![]() ![]() |
With a map I've managed 30/32 in my TD6 and that was between 60/70 on a motorway.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Brought mine a month ago.
That was with Continental Cross Contact tyres on 20" wheels. On my 18" winter Pirelli Scorpion Winter I never really saw over 25.
Might also be worth mentioning if it's the computer or brimmed you're quoting. |
markyp Member Since: 05 Feb 2013 Location: essex Posts: 234 ![]() ![]() ![]() |
^ computer was reset, tank was full and of we went, interesting to see
...and like I say I've not found the computer to be very accurate, re-set or not. |
If you really were going between 50-60 I would say that's accurate as its a very economical speed for TD6 but how often can you travel "Constant" at that speed.... |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
I have just come back from the south of France , filled the tank computer said 31 mpg over 755 miles at 70mph.
^ You don't budget with a Fatty , you allocate funds |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7986 ![]() ![]() ![]() |
If you work out how much it's really doing compared to how much the computer says, you can then change the mpg trim in the hidden menus, so it will be spot on.
I don't normally drive like an old tart ![]() 1978 Pontiac Firebird 2010 Fiesta |
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
Guessing this thread doesn't apply to petrol engines. 2 months into ownership and think of buying shares in Exxon. |
