Home > Maintenance & Mods (L322) > No faults for last 2 years, it's bong time!
Mr Tee
After spending a small fortune to get the old beast up to scratch, the inevitable bong "fuel injection system fault" has re-appeared again.
Found a new local indy, who will have Autologic within the next month or so, he just uses the IID tool at present. Fault listed as pressure sensor, which was replaced a couple of years back, so we are going for a little known part that was released as a fix for the TD4 engine first , before the bigger money gets thrown at it. The part is to replace the loom connector for the pressure sensor part number YNQ503220 , cheap enough at £40, so we shall see how this goes. Car runs perfect on light throttle, when asked to kickdown, immediate bong, then limp home mode! If this doesn't work, then either the high pressure pump, ouch or the 2 injectors that I was too tight to replace when the car was seriously unwell a couple of years back! Will update on progress...... Big Cry
Post #268332 1st Jul 2014 10:57am
SteveMFr
Site Sponsor
It sounds like an injector issue, tbh. Embarassed Sorry.
We are in the process of adding the live values for the injectors on the TD6. Just a few more days...
Who is your indy? With the upcoming release of the IIDTool Pro he will have less for much, much more money with an Autologic (unless he services many different makes other than LR).
Cheers,
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #268342 1st Jul 2014 12:43pm
Mr Tee
Indy is MMP Landrover, based in Dundee.
Post #268365 1st Jul 2014 2:24pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
^ I noticed their Disco sitting in Dunsinane Industrial Estate the other day, would be interested to hear how you get on with them Thumbs Up The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #268378 1st Jul 2014 3:48pm
Mr Tee
Hi Jim,
Nice bloke, used to work for Strathearn Engineering before going it alone, seems to know his stuff, although I am at the early diagnosis stage with mine. Will give more feedback as we progress, would be great to have someone closer to home that is trustworthy as I was fed up going to Auchterarder!
Post #268380 1st Jul 2014 3:51pm
Martin
Site Admin
That's Disco_Mikey from DISCO3, top guy Thumbs Up
http://www.disco3.co.uk/forum/member-disco_mikey.html
Post #268388 1st Jul 2014 4:43pm
wackyjim
Ahh Mikey!!..He lives close to me and has picked up my car for service at Strathearn in the past. Thumbs Up The forums premier drug dealer and human trafficking consultant
Post #268415 1st Jul 2014 6:41pm
Mr Tee
Then the battery light came on today, then kaput, wouldn't start! Magic, new alternator needed to add to my woes! Think it's maybe time to save for a replacement .
Although via my AA cover, think I may be covered for the repair, which would be nice.
Post #271302 16th Jul 2014 9:08pm
wackyjim
Lets hope so!! Thumbs Up The forums premier drug dealer and human trafficking consultant
Post #271322 16th Jul 2014 9:48pm
Mr Tee
Well well, the aa will cover the replacement of the alternator + the labour! All it will cost me is............£35! At last some decent news. Thumbs Up Thumbs Up
Post #271491 17th Jul 2014 9:26pm
Mr Tee
So that's the alternator done, back on the road after driving a crv for the past week.
Full service including crank case breather, looked like it hadn't been changed in a long time if at all
Injection system fault fixed. Not an injector as it turns out, thank fook, mike replaced a part of the injection loom & disconnected the tuning box & all is well again for a wee while at least . Car sounds much better, didn't have time to fanny about reconnecting the tuning box so it was either both or one of them, I'll leave it off just now. Mibbe the fuel consumption will increase now!
Post #272827 25th Jul 2014 8:57pm
