Home > Technical (L322) > Unidentified knocking from underneath
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Hi everybody,
In need of some advice if anyone can help.
I have an unidentified knocking noise on the underneath of my 2004 FF 3.0 Diesel Vogue.
This knocking can be heard very clearly at low speeds whilst travelling over uneven surfaces like a bumpy road etc, on the smooth flat complete silence.
I have recently had both rear N/S & O/S hub bushes replaced but can't find the cause of this knock.
I sounds like the exhaust knocking on the chassis that sort of noise only when going over a bumpy surface in rhythm with the suspension. After having the rear hub bushes changed due to the noisy squeak my local independant dealer they checked underneath and couldn't find anything lose.
Any ideas folks, there is no transmission play, goes into gear smooth, air suspension all seems fine, no knocking under acceleration or breaking, fine on cornering both low or high speed, this knock seems to appear at low speeds on uneven surfaces.
Thanks in advance Thumbs Up
Post #269982 9th Jul 2014 9:15pm
GraemeC
Try a search for front lower arms - believe you can get this kind of knocking if worn
Also, I think anti roll bar drop links are another suspect
Good luck finding the cause Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #269996 9th Jul 2014 9:55pm
anorakmark
Thanks for you help, will get checked.
Post #269998 9th Jul 2014 9:57pm
allycraven
Drop links usual suspects and peanuts to change.... '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
'59 Ford Kuga Diesel (boring but AWD and 40mpg...)
2007 (07) Subaru Forester XTen 2.5 Turbo. (Roundabouts are fun again!)
2007 (07) 4.4 V8 Vogue (gone)
Post #270005 9th Jul 2014 10:24pm
Arb Drop links Thumbs Up
Cheap as chips, give them a wiggle and a twist, should be reasonably stiff to move with no play. If they haven't been done it's a good place to start. There is nothing that can't be fixed with a hammer😜😜
Post #270016 9th Jul 2014 11:28pm
Googsy
Dont buy the cheap ones. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #270022 10th Jul 2014 12:21am
ebajema
Just get originals from Duckworth Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #270023 10th Jul 2014 12:39am
anorakmark
Thanks Guys, had the old girl out today listening for noises, seems like the noise is more to the rear than front, as if exhaust is knocking on the boot floor. it's difficult to tell exact location as the sound proofing in the FF vogue is brilliant, but sounds like centre to rear.
Post #270102 10th Jul 2014 1:56pm
Rear drop links? There is nothing that can't be fixed with a hammer😜😜
Post #270178 10th Jul 2014 9:47pm
I had exact same problem, definitely sounded like it was coming from the back, even passengers said so.
Replaced the front ARB drop links and problem solved.
As previously said, use LR ones, otherwise you will be back replacing them again in 6 months. .
Post #270182 10th Jul 2014 9:56pm
anorakmark
Thanks guys for all your help, drop links it is.
Post #270201 10th Jul 2014 11:39pm
The LR ones are lemforder items, they even have the logo on them.
They can be had from ecp for a good price. There is nothing that can't be fixed with a hammer😜😜
Post #270234 11th Jul 2014 7:19am
And as we know from RRPhil, Lemforder are a subsidiary of ZF and known for their high quality. Thumbs Up
Post #270246 11th Jul 2014 8:29am
Very lemony (as in sharp) today Kurt Twisted Evil .
Post #270304 11th Jul 2014 3:37pm
