Home > Maintenance & Mods (L322) > Waterfall in car! |
Door opening water is normally water getting trapped between the two door SEALS more common on back doors. Check both inner and out seals are undamaged and seated correctly although not sure how this could get to door speakers etc (Normally just dumps a puddle on your feet) |
13th Jul 2014 4:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
there is a solution where you put a bit of wood on the bottom of the door and press the door against it causing the door to bend slightly....do a search its here somewhere.. ... - .- -.
13th Jul 2014 4:47pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
When I open the top half of the boot after heavy rain, waters always splashes on the the parcel shelf at either side. Any cure for this or is it a design fault ? |
14th Jul 2014 7:48am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Yes, its a design fault feature GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
14th Jul 2014 8:26am |
