Home > In Car Electronics (L322) > iOS7 + iPhone 5 + RR Bluetooth issues
d3rm0
After updating my iPhone 5 to iOS7 the car keeps muting or breaking while I am in a call. It repeatedly cuts the phone audio off DAB comes back on, then the RR screen says "call ended" after a couple of seconds the call connects again, mutes the DAB and the caller comes back through the speakers. This process of audio on and off keeps looping round every 10 seconds or so. I believe the phone is still connected as the EE symbol and signal strength are visible all the time.
Has anybody else had any issues like this? Big Cry
Post #213298 30th Sep 2013 9:34pm
sometimes on my 2007 one.... All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #213312 1st Oct 2013 5:52am
d3rm0
I assume by the lack of response (apart from Angel, thanks) that it is my iPhone 5 that is faulty which I can get exchanged. The car is a 2012 model
Post #213472 1st Oct 2013 6:47pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Try turning off the phone and back on again! There's been many connection issues with ios7 and aftermarket devices!!
Post #215034 7th Oct 2013 8:12pm
andrewcuz
2010 Range Rover HSE 5.0 V8 Santorini Black
Re: iOS7 + iPhone 5 + RR Bluetooth issues
I have the exact same issue as d3rm0. Phone keeps briefly cutting out, shows "call ended". This happens every 10 secs or so. Problem stops after 5 minutes of call time. Extremely frustrating.
Post #215534 9th Oct 2013 6:22pm
d3rm0
I have wiped the iPhone and reinstalled a backup with no joy. My 2013 5 Series doesn't miss a beat
Post #215939 11th Oct 2013 6:58pm
Rotorboater
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I have the same problem, iPhone 5s and 2012 RR, it's getting really annoying, I get cut off for a few seconds and my caller hears my radio, is this just a RR problem or is it an iPhone issue?
Post #217002 16th Oct 2013 9:08pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I have a 5s with iOS7 and it works fine in my MY11. I do however have the digital TV country selected as the USA to temporarily overcome the intermittent interruptions due to some recent change in the digital program guide transmissions. Maybe this is what is causing your problem? Worth a try I'd have thought. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Previously: 4.4 TDV8 Vogue Baltic Blue MY11
Post #217008 16th Oct 2013 9:58pm
d3rm0
I thought it was related to the DVB issue but like others I have had the TV set to USA from the beginning. I haven't been driving my FF for the last couple of weeks so I haven't experienced the issue, it's a 12MY. My BMW F10 is a 2013 and is perfect with iOS7 so it does point towards a Land Rover issue. I think it maybe a Bluetooth compatibility issue. All you can do is report it to the dealer.
Post #217022 17th Oct 2013 5:52am
Rotorboater
Thanks Baron, that's sorted it Thumbs Up
Post #217415 18th Oct 2013 4:47pm
Jareer
Jordan
I have the exact same problem and the TV adjustment as suggested by Baron did not work.
This is really frustrating, any other solutions?
Post #219795 30th Oct 2013 6:24pm
warren1712
England 2019 Range Rover 2.0 PHEV Corris Grey
USA selected and iPhone 5 still cuts on and off Big Cry 2021 L405 Westminster P400e
Post #219850 30th Oct 2013 9:05pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
I have the exact same issue, IOS7 iPhone5 and L322 2010
I hope someone has found the answer?
Post #236363 21st Jan 2014 9:13pm
Baben
Tried the TV setting change and if anything it makes it worse.
Its at the point now that I can't even use the bluetooth while driving, which makes it quite frustrating, as I do drive a helluva lot and then lose all they time where I could be calling clients. The challenge is it doesn't happen all the time, particularly when I am trying to show Land Rover service guys the symptoms...
LR managed to drown my whole set of computers in the boot (don't even ask how - they were testing a sunroof leak and thought it wise to throw a bucket of water on the roof) so they have replaced the bluetooth module with a new one, and the issue just gets worse and worse.
The issue doesn't happen when I use my HTC OneS though, so it MUST be some crazy compatibility issue with the i5 and the FFRR bt stacks
My wife has just received a i5S and we will test this in the car when we get a chance. If this works then the solution is obvious.
Any more wisdom on this?
Post #278439 1st Sep 2014 12:00pm
ebajema
The solution is, switch to Samsung Twisted Evil MY 2010 5.0 SC Galway green and sand interior!!
Post #278441 1st Sep 2014 12:14pm
