Home > In Car Electronics (L322) > Towing electrics - max current ?
I was thinking of pruning a couple of super bright LED reverse lights on my boat trailer - but would be a 3.5A draw
I have no idea how the towing electrics are wired/fused
I could run it off the fridge circuit with a relay if needed.
Does anyone know what the reverse circuit is rated at ?
If not, I guess I'll just try it our & see what blows Smile
Post #271884 20th Jul 2014 10:39am
IMO you would be better using the reverse circuit to switch a relay and use the relay contacts to feed your reverse lights.
You could then take the feed for the additional lights from one of the permanent +12v feeds to the sockets. Doing this means you won't upset either of the lighting/tow ECU's.
Tis what I would do. Thumbs Up
Post #271889 20th Jul 2014 11:43am
Thanks - confirmed my inclination - relay & use the fridge circuit Thumbs Up
Post #271891 20th Jul 2014 11:50am
