Home > Technical (L322) > 2003 td6 abs pump
Needle
2003 Range Rover SE Td6 Java Black
2003 td6 abs pump
can anyone advice if a replacement abs ecu module needs to be coded to the new car?
Post #273055 27th Jul 2014 2:52pm
RAVE only indicates the refitted ecu MUST be tested using Testbook/T4 to ensure correct operation, nothing about a new one... .
Post #273056 27th Jul 2014 3:03pm
