![]() | Home > Technical (L322) > Pulled out fuse 25 now car is having a fit. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Sharp intake of breath thro clenched teeth.....Not fuse 25. |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Just tried resetting it.
Is your battery fully charged? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8804 ![]() ![]() ![]() |
Disconnect battery, wait 10mins, reconnect, make sure all doors and bonnet are shut, lock and unlock car with remote and then try it... had a similar issue with mine and that sorted it...
Battery is stating 10.85. Is that fully charged? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
nope.... ... - .- -.
What should it be and can I buy a charger from Halfords and charge it whilst in the car? |
Your battery is flat, should be at 12.6V
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
I would jump it first to ascertain that it is the battery, use the body mounted +ve and -ve terminals, not the battery itself |
Just jumped it. Car running is about 13.10.
If 13.1V is with the engine running after a flat battery it's definitely not very good.
