Home > Technical (L322) > Intriguing ticking noise
destructimo
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi All,
Hopefully the experts on here will know exactly what this is Very Happy
I've started to notice a ticking from the car. The symptoms are:
When the car is started all is quiet for a couple of seconds and then the ticking starts. The ticking continues while the car is holding its revs above 1000 rpm. After a few seconds the revs drop and then the ticking stops. Reving the engine in P is all quiet, as it is in N.
Once in D and moving off the ticking comes back Shocked
It seems to then continue but decrease in volume as the car warms up.
Any ideas gents?
Cheers
Clive
Post #274401 5th Aug 2014 12:44pm
viscous fan catching on something? ... - .- -.
Post #274415 5th Aug 2014 2:19pm
VANOS ? 2008 MY Supercharged
Post #274428 5th Aug 2014 4:20pm
destructimo
Thanks for the replies.
Well it has to be something that runs automatically for a little while with a cold engine...and then only runs when the transmission is in Drive.
The tick is commensurate with engine speed btw.
Cheers
Clive
Post #274453 5th Aug 2014 5:05pm
destructimo
Hi All,
Had a bit more of a listen and play about.
I think it might be an exhaust leak somewhere in front of the cats. I can just about hear it in P blipping the throttle at low revs, gets quieter as it warms up, but I can induce it a bit louder by putting some load on the engine by turning the AC on.
So from a cold start is there something that puts load on the engine while it's holding the revs high during warm up?
Cheers
Clive
Post #274675 6th Aug 2014 2:58pm
Have you checked all visible belts for breaking up? Previously..
Post #274697 6th Aug 2014 5:36pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Have you checked for something obvious such as a screw or bolt head stuck in a tyre, at low speed you will hear it with every rotation.
Post #274810 7th Aug 2014 1:09pm
destructimo
Hi Guys,
Downloaded an app for the old phone that measures bpm as you tap the screen....
The tick frequency is half that of the engine speed so I'm just in the process of checking the spark plugs are done up properly (once my oppo comes back with the correct sized plug socket) Very Happy
Spark plugs were a little loose but they aren't the source of the noise.
So I suspect it's an exhaust leak on the manifold somewhere. I'll have a proper look next week when we do the brakes.
Cheers
Clive
Post #274814 7th Aug 2014 2:29pm
destructimo
Hi All,
Just to close this.
Found the leak where the manifold joins into the single pipe.
The dealer sorted it out today and the car is again sounding as it should, and driving much better.
Cheers
Clive
Post #276542 19th Aug 2014 8:17pm
