Home > Maintenance & Mods (L322) > Car wont lift suspension |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
The system has logged a "hard" fault, which means it has deactivated the system until the fault is cleared with a diagnostic tool.
7th Aug 2014 5:32pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
Pro diagnostic tool won't even work on the comma port works fine on my car so tool fine |
7th Aug 2014 5:46pm |
I presume you have checked the fuses?
7th Aug 2014 6:15pm |
Both them fuses are ok and have a live but the switch in console dead as a dodo box under the passenger seat that the header go to connections are good and not corroded like I have seen mmmmm car has stood a few months but battery is good. Starting to wonder if a mouse has been at wires LOL |
7th Aug 2014 6:28pm |
As far as I can see from the wiring diagram the only things that can inhibit power to the switch panel are the two fuses above and the air suspension relay located on the rear fuseboard.
7th Aug 2014 9:04pm |
If there is a hard fault the dash switch will lock out and not operate anything until the fault has been cleared |
7th Aug 2014 10:02pm |
As per my post. It won't do anything until reset. Zilch.
7th Aug 2014 10:13pm |
But the com sport won't talk to the computer so cannot wipe any faults. It's a open reader that has always worked and software all up to date and license up to date on the program's so struggling. But he has found on the web that a canbus fault on headlights might cause it so is checking that today. I will keep you posted |
8th Aug 2014 8:28am |
