Home > In Car Electronics (L322) > Caravan led tail & stop lamps , flashers
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Hi am collecting a new caravan shortly with led road lights. . Have a 2006 rangerover with factory fit towbar &electrics . Will this work ok with bulb sensors Or will I get problems . Haven't got caravan yet to test
Post #273621 30th Jul 2014 3:21pm
sako243
Depends completely on the setup of the LEDs. Done properly there will be no issues but I recently towed a car transporter which had LED tail-lights but no current limiting resistor hence they went haywire when indicating.
[edit]Should only matter on the indicators since the car uses the current draw to work out the resistance of the bulb and therefore whether one has gone or not.[/edit]
Post #273690 30th Jul 2014 10:30pm
miggit
Hi, it all depends on the trailer wiring on the Range Rover, as far as I'm aware the only factory fit wiring that will cope with leds is the 13 pin plug option, which I have and can confirm works well. If your caravan makes the indicators go into meltdown mode don't worry, it should be an easy fix. If you look on ebay there are thousands of ballast resisters to cure this problem. If you search for "ballast resister led" you should be ok, they start at £2.25ea and go up from there. Once you have them all you do is wire them between the indicator wire and earth on the caravan, and all will slow down again Cool
Post #273695 30th Jul 2014 10:51pm
Swiftman
Thanks for your reply. Asked bailey caravans they said drive with side & tail lamps on really high tech answer Rolling with laughter
Post #275338 11th Aug 2014 4:24pm
