![]() | Home > Technical (L322) > pressure static when filling |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
I've had temperature overheat fault on my compressor before which is typical on a failing compressor (taking too long to pressurise so overheats). On investigating the wheel well had about an inch of water in it. On removing the water and giving it a chance to dry out it was still giving the overheat warning (despite not running so completely cold) so I forced it to run using IID tool. This dried it out the sensor enough to work correctly from then on and has been fine for the last two years.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Aha |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Sounds like that sorted it, top job, been thinking of piggy backing another compressor on mine to help out the raised off road height.... may have a play soon.... Pete
I'm going to call this solved for me |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Good to here that pall |
LandieMan Member Since: 05 Nov 2013 Location: Christchurch Posts: 1 ![]() ![]() |
Hi Joe90,
bmkennedy Member Since: 17 Oct 2022 Location: SCOTLAND Posts: 1 ![]() ![]() ![]() |
if Weejock is at all available would very much your advice regarding the pressure switch on the L322 2004 air tank. Anyone else who may be able to help serious appreciation. you seem to know a load about testing to see where the issue may be on the pressure switch, our tank reads 23bar, replaced pressure switch and tank still reads 23bar, tank is empty but pressure not changing with new switch. in this chat you advised measure on yellow wire around 5v, is this a constant voltage, right now we have no volt's whether ignition on or off, have ground.
