![]() | Home > Technical (L322) > Remote receiver. |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
Can anyone tell me where the key fob receiver is on a 07 supercharged. I still have no remote locking/unlocking. I have tried everything else, the only thing left is the receiver. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
When this happened on mine (also 07) it was eventually traced to the key battery being dead - still started the car but remote wouldn't work. Bought a key from Dan and £15 later for the programming we were done (2nd time round - took a bit for the garage to suss it all out) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
the RF receiver is installed at the rear of the roof, above the roof liner, to the left of the vehicle
Replaced batteries in both fobs even though they tested OK. I managed to pick up a receiver cheap so will try that this afternoon. What I dont understand is the way it failed. Put it in the garage unlocked one day and the next day it didnt work. Stan, Thanks for the pic. Did that come from Rave because if so its not on my disk. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
diagram came from the WM which is linked here, http://www.fullfatrr.com/forum/topic17623.html
I've got that manual on disk. I didnt find it. Regarding battery reset I guess that that has been tried several times over the past 2/3 months. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
The same thing happened to me just a few weeks ago , more than likely you keys have lost sync with the car and after a battery re-set you should be able to do it yourself ;
